Grand Starex: HARI vs. Pitstop/gray market
Shoutbox
zkie: gud eve po! gus2 ko lng po mag ask if sino po my alam na nbibilhan ng valve cover gasket for hyundai excel GLS...sana po ung malapit sa cavite area.thanks! Jul 29, 2015 21:22:20 GMT 8
arl: ask ko lng po if saan po pwede makakuha kopya ng all hyundai parts catalogue and accessories ty Aug 3, 2015 0:06:14 GMT 8
cyclone1537: what bulb size ang foglights ng Grand Starex? Aug 9, 2015 1:55:34 GMT 8
coolmon: sheilahush, naka indicate sa user manual ng starex kung saan Makita ang engine number. Aug 11, 2015 12:41:26 GMT 8
coolmon: makikita sa user manual ng starex kung nasaan ang engine num. Aug 11, 2015 12:43:59 GMT 8
coolmon: anybody pls.. ask ko lang kung san makita ang drain plug at filling hole ng automatic transmission ng grand statex vgt 2011 na walang dipstick. Aug 11, 2015 12:48:03 GMT 8
awake: bago lang ako dito sa group , ask ko lang kung saan makakabili ng murang dashboard ng hyundai 1999 model tnx Aug 14, 2015 22:46:32 GMT 8
benson: Mga sir pwede po bang magtanong san po ba nakaka bili ng OIL SEAL para sa PUWET ng AUTOMATIC TRANSMISSION nearby CAVITE? Aug 16, 2015 19:16:41 GMT 8
hansam: mga sir mei lam po b kaung ngrereplace ng sliding door bearing ng starex '99 model Aug 17, 2015 12:03:50 GMT 8
ian: please help! i want to find out where I can purchase a instrument cluster plastic cover only of my 2011 starex without buying the whole set. My plastic cover has a crack on it. Aug 17, 2015 12:43:06 GMT 8
rgmontemayor: hello...would like to ask anyone who can recommend a good electrician from south area (Las Pinas, Alabang, Paranaque) who can repair instrument panel gauge for 2004 GRX Starex. The Fuel Gauge is working but it does not go all the way to the empty needle sl Aug 17, 2015 16:26:54 GMT 8
rgmontemayor: ..slot... Aug 17, 2015 16:27:09 GMT 8
rgmontemayor: and the trip meter (trip A and B) can't be used because the needle where you press to change from odometer reading to trip meter reading is broken.. Aug 17, 2015 16:28:19 GMT 8
jesse: mga sir newbie po ako dito dis coming saturday august 22 2015 plan ko po sana bumili ng timing belt para sa starex 2004 grx ko..ok lng po ba na ma meet up po ako isa sa inyo para matulungan po akong makabili wer mura n quality...jes po from pampanga Aug 19, 2015 11:53:14 GMT 8 *
jesse: ang mahal po kz dito sa probinsya namin...in case po na may magka interest mga sir eto po nos ko 09206398395 salamat mga sir Aug 19, 2015 11:54:21 GMT 8
rosevb05: Sir na try nyo na po bang mad palit ng fluid? Dot 4? Aug 23, 2015 21:52:10 GMT 8
mafd: mga sir meron ako hyundai accent HB 2013. 2 years na din sa akin yun unit at nasa 37km n dn natakbo nia. napansin ko kasi n hirap na cia bumatak at medjo maingay n din tunog nia compare dati ng nkuha ko cia. brand new ko cia nkuha. normal po ba yun s 2 yir Aug 24, 2015 9:09:57 GMT 8
psalm23: HI any knows where to bring my starex for repair of ABS? apparently, the break system/fluid is not bleeding to the front-right wheel. I was told to replace the ABS, but the price is so high. Can you please help me or suggest an ABS specialist? Aug 27, 2015 12:21:11 GMT 8
max: Hi! Ask ko lang, anybody knows the price of Hyundai Grand Starex VGT crdi Manual transmission Clutch Master Primary and secondary? Just want to know para may basis ako pag pinabili ako kasi nag down na clutch at papalitan daw yung clutch master..many thanx Aug 27, 2015 21:00:41 GMT 8
jabz: Hi mga Sers...me problema ang turbo charger assembly at rack end pinion ng Starex 2012, napa check ko nsa sa casa at sobra mahal ng quotation pede ng pang down sa isang starex uli...meron ba kau na marekomenda na Hyundai Outlet spare parts? thanks na lng.. Aug 31, 2015 20:42:56 GMT 8
